Hey everyone, I wanted to share my recent experience with configuring sensors for the Energy Dashboard. It’s been a bit of a learning curve, but I think I’ve got it figured out!
I’ve been using multiple smart plugs on my desk, and I wanted to track their energy consumption more effectively. I started by creating a sensor to sum up the power usage in watts. That part was straightforward, but when I tried integrating it into the Energy Dashboard, I ran into some issues.
The dashboard requires sensors to be in kWh, so I thought using a Riemann integral to convert the watt sensor would work. I set it up, but unfortunately, I encountered an error message. After some research and trial and error, I realized that the integral setup wasn’t the right approach. Instead, I needed to adjust the sensor configuration to ensure it provided data in the correct format.
Here’s what worked for me: I created a new sensor specifically for kWh by adjusting the transformation settings. I also made sure to set the correct units and update intervals. It was a bit tricky, but breaking it down step by step helped a lot.
I’d love to hear if anyone else has tips or alternative methods for configuring energy sensors. It’s such a useful feature, and getting it right really helps with monitoring and optimizing energy usage!
Happy tinkering!
