After struggling with the Tradfri Gateway’s reliability, I decided to switch to direct OpenHAB control for my IKEA Fyrtur blinds. Here’s how I made it work!
Setup Overview:
- Hardware: IKEA Fyrtur Blinds, Tradfri Signal Repeater, Tradfri Open/Close Remote
- Controller: Nortek GoControl HUSBZB-1
- OpenHAB Version: 3.2.0-1
Steps I Took:
Device Binding:
- Started with the Signal Repeater. It showed up as an ‘Unknown ZigBee Device’ initially but was identified after a few seconds.
- Added the blinds next. They were a bit tricky but eventually paired successfully.
- The remote was the most challenging. I had to press the reset button multiple times and place it directly on the repeater for about 10 minutes until it connected.
Console Magic:
- Collected the IEEE addresses of each device from their Thing pages.
- Converted these addresses to network node numbers using the
zigbee nodescommand. - Verified the remote’s firmware version to ensure it was compatible with direct control.
Binding the Remote:
- Used the OpenHAB console to bind the remote directly to the blinds using the
zigbee bindcommand. - Tested the setup, and voilà! The remote now controls the blinds without needing OpenHAB in the loop.
Benefits of This Setup:
- Reliability: No more gateway crashes. The system is more robust now.
- Direct Control: Even if OpenHAB goes down, the blinds can still be operated manually.
- Simplicity: No need for complex rules or message parsing on the OpenHAB side.
Challenges Faced:
- The remote pairing process was frustratingly time-consuming.
- Initial setup required some command-line comfort, which might be daunting for beginners.
Tips for Others:
- Ensure all devices are on the latest firmware before attempting direct control.
- Be patient with the remote pairing. It might take several tries.
- Familiarize yourself with the OpenHAB console commands for smoother troubleshooting.
If anyone has questions or runs into issues, feel free to ask! I’m happy to help where I can.
Final Thoughts:
This setup has been a game-changer for my smart home. The ability to control the blinds directly from the remote, even without OpenHAB, gives me peace of mind. It’s a great example of how OpenHAB’s flexibility can solve real-world problems!
