I’ve been diving into the world of smart home automation lately, and I must say, it’s been an exciting journey! One of the challenges I encountered was configuring a Z-Wave device, specifically the ZOOZ S2 multi switch. I was trying to change a configuration parameter directly from the admin console, but it just wouldn’t work. I could change it through a program, but not via the console. It was quite puzzling!
After some research and trial and error, I figured out that the ‘Write changes’ command wasn’t being sent properly to the device. It worked perfectly when I used the ‘Then’ command in the program, which was a bit frustrating but also a learning experience. I ended up taking screenshots to visualize the process better, and it helped me understand the workflow much clearer.
Moving on to another project, I decided to set up multiple Sonoff switches on my Hass.io system. This was a new setup on a Raspberry Pi 3 Model B with a 32GB Class 10 SD card. I installed the TasmoAdmin addon, which worked great for controlling both Sonoff Basics. However, I ran into an issue where only one of the switches worked properly. The second switch would toggle off but not stay on, which was perplexing.
I spent hours reviewing my configuration files and comparing them to online examples, but nothing seemed to resolve the issue. Finally, I decided to try a different approach by creating separate entries in the switches.yaml file for each switch. To my delight, this solved the problem! It was a bit of a rollercoaster, but it taught me the importance of meticulous configuration and the value of persistence.
This experience has really highlighted how rewarding it can be to troubleshoot and resolve these kinds of issues. It’s all about breaking down the problem, testing different solutions, and learning along the way. I’m now more confident in tackling similar challenges in the future. If anyone has any tips or tricks for configuring Z-Wave devices or Hass.io setups, I’d love to hear them! Let’s keep the smart home revolution going! ![]()
