Connecting My Tankless Water Heater to Smart Home: Success Story
Hey everyone, I wanted to share my experience connecting my Navien Navlink Lite tankless water heater to my smart home setup. I’ve been curious about integrating this device for a while now, and after some research and experimentation, I finally got it working! :tada:
First, I had to figure out the right integration method. The Navien Navlink Lite is a bit tricky since it’s not as commonly supported as other smart home devices. I reached out to the community here and found some helpful tips. Turns out, the best approach was to use Home Assistant with a custom integration. I had to enable developer mode and install the necessary Python packages, but the process wasn’t too bad.
Once everything was set up, I could monitor my water heater’s performance in real-time. Now, I can track temperature, flow rate, and even receive alerts if there’s an issue. It’s amazing how much more control I have over my heating system now! :ocean:
I also set up some automation rules. For example, during colder months, the heater automatically adjusts to a higher temperature in the morning when we usually take showers. It’s little touches like these that make the integration truly worthwhile.
If anyone else is looking to connect their Navien Navlink Lite, I’d be happy to share more details or walk you through the steps. Let me know in the comments! :speech_balloon:
Cheers,
