Creating a Custom Automation Using Fake Devices
Hey everyone, I wanted to share my recent experience with creating a fake device in Home Assistant. It’s been a fun and educational project, and I thought I’d walk through the process for anyone interested in trying something similar.
Why a Fake Device?
I’ve been experimenting with automations that trigger via webhooks, and I wanted a way to easily control the status of these automations directly from the Home Assistant UI. A fake device seemed like the perfect solution—it acts just like a real device but gives me the flexibility to change its status on the fly.
How I Did It
  1. Setting Up the Webhook: I started by setting up a simple webhook that triggers a specific automation. This involved creating a new automation in the configuration editor and adding a webhook trigger. It’s surprisingly straightforward!
  2. Creating the Fake Device: Next, I created a fake binary sensor using the REST API integration. This sensor acts as the status indicator for my automation. I set it up so that when the webhook is triggered, the sensor’s state updates accordingly.
  3. Customizing the UI: To make things even more user-friendly, I added a card for this fake device to my dashboard. Now, I can see the status of my automation at a glance and even toggle it manually if needed.
Tips and Tricks
  • Use Descriptive Names: When setting up your fake devices, use clear and descriptive names so you can easily identify them later.
  • Test Thoroughly: Before fully integrating your fake device into your automations, test it extensively to ensure it behaves as expected.
  • Documentation: Keep detailed notes on how your fake device interacts with the rest of your system. This will save you time if you ever need to troubleshoot or modify your setup.
Why This Matters
Creating a fake device opens up a world of possibilities for customizing your Home Assistant setup. It allows you to bridge gaps between different integrations and create automations that are tailored specifically to your needs. Plus, it’s a great way to learn more about how Home Assistant works under the hood.
I’d love to hear from anyone who has tried something similar or has tips for improving this setup. Let’s keep the ideas flowing! :rocket:
