Creating a DIY CO2 Sensor with ESP32 and SCD41
Hi everyone, I’ve been diving into the world of DIY sensors lately, and I wanted to share my experience with creating a CO2 sensor using an ESP32 and the SCD41 sensor module. This project has been a fantastic learning experience, and I’m excited to walk you through it!
Why a CO2 Sensor?
I’ve always been interested in air quality monitoring, especially since I spend a lot of time indoors. High levels of CO2 can make spaces feel stuffy and affect productivity, so having a sensor to keep track of this is really useful.
The Setup
I decided to go with the SCD41 sensor because it’s compact, accurate, and comes with built-in temperature and humidity compensation. Pairing it with an ESP32 made sense due to its versatility and support for MQTT and web servers. I also added a BME280 sensor for better air pressure compensation and some LEDs for visual feedback.
Challenges and Solutions
One challenge I faced was getting the sensor to communicate properly with my Home Assistant setup. After some research, I found that using ESPHome simplified the process significantly. ESPHome’s YAML configuration made it easy to define my sensors and set up the necessary automations.
Tips for Success
  • Power Management: The ESP32 and LEDs draw quite a bit of power, so I recommend sticking with a USB power supply unless you’re ready to optimize for battery use.
  • LEDs for Feedback: While the LEDs are great for quick visual cues, I’m considering upgrading to a small LCD display for more detailed information.
  • Firmware Updates: Keep an eye on the ESPHome updates, as new features and bug fixes are regularly added.
What’s Next?
I’m planning to integrate this sensor into a more comprehensive air quality monitoring system. I’m also looking into adding support for VOC detection with a BME688 sensor. Stay tuned for more updates!
If you’ve tried similar projects or have tips to share, I’d love to hear from you. Happy building! :blush:
