Hey everyone,
I wanted to share my experience with setting up a Group:String in openHAB to monitor the health of my NAS disks. I had a bit of trouble getting it working at first, but I figured it out after some research and trial and error. Hopefully, this helps someone else who’s struggling with similar issues!
The Problem:
I have several disks in my NAS, each reporting their status via SNMP as either GOOD, BAD, or FAILED. I wanted to create a group that would show the overall health of all disks at a glance. However, when I first set it up, the group state was always UNDEF, even though the individual disk states were correct.
The Solution:
After some digging, I realized I needed to use transformation rules to properly map the states. Here’s how I did it:
- Define the Group and Members:
I created a Group:String item and added all my disk status items as members.
plaintext
Group:String nas_health “NAS Health [%s]” {Transformation=MAP(nas_health.map)}
String disk1_state “Disk 1 Status” {snmp=[…], Transformation=MAP(nas_health.map)}
String disk2_state “Disk 2 Status” {snmp=[…], Transformation=MAP(nas_health.map)}
- Create Transformation Rules:
I added a transformation file (nas_health.map) to map the individual states to the group state.
plaintext
GOOD=GOOD
BAD=BAD
FAILED=FAILED
UNDEF=UNKNOWN
- Set Up the Group Logic:
I used a Rule to evaluate the states of all group members and determine the overall health.
java
rule “Update NAS Health”
when
Item disk1_state changed or
Item disk2_state changed or
Item disk3_state changed or
Item disk4_state changed or
Item disk5_state changed or
Item disk6_state changed or
Item disk7_state changed or
Item disk8_state changed
then
val List states = [
disk1_state.state.toString,
disk2_state.state.toString,
disk3_state.state.toString,
disk4_state.state.toString,
disk5_state.state.toString,
disk6_state.state.toString,
disk7_state.state.toString,
disk8_state.state.toString
if (states.contains("FAILED")) {
postUpdate(nas_health, "FAILED")
} else if (states.contains("BAD")) {
postUpdate(nas_health, "BAD")
} else {
postUpdate(nas_health, "GOOD")
end
Tips:
- Logging: If your group isn’t updating as expected, enable logging for the rule to see what’s happening.
- Visualization: You can customize the visualization in your sitemap by using different icons or colors for each state.
- Alerts: Consider setting up notifications for when the health changes to BAD or FAILED.
This setup gives me a clear overview of my NAS health at a glance, and it automatically updates whenever any disk status changes. It’s been a huge help in monitoring my system without constantly checking each disk individually.
If anyone has questions or suggestions for improving this setup, feel free to reach out! I’m happy to share more details or troubleshoot if something doesn’t work as expected.
Best regards,
