Creating a Smart Bathroom Automation with Humidity Sensors
Hey everyone! I’m super excited to share my recent project where I set up a smart bathroom automation system. I wanted to make my bathroom more convenient and energy-efficient, so I decided to integrate a few smart devices and create some custom rules. Here’s how I did it:
The Goal:
I wanted the bathroom lights to turn on automatically when the bathroom is in use, adjust the brightness based on the time of day, and also control the exhaust fan based on humidity levels. Plus, I wanted everything to be controlled without any physical switches on the wall—just using sensors and my smart hub.
The Setup:
  • Sensors: I installed a humidity sensor and motion detectors to detect when someone enters the bathroom.
  • Lights: I used LED tape lights around the ceiling perimeter, controlled by a smart dimmer.
  • Exhaust Fan: I connected the inline extractor fan to my smart hub so it can be turned on/off automatically.
The Automation Rules:
  1. Motion Detection: When motion is detected, the lights turn on to a medium brightness. After 10 minutes of no motion, the lights dim to a lower brightness and then turn off completely after another 10 minutes.
  2. Humidity Detection: If the humidity sensor detects a high level (like after a shower), the exhaust fan turns on automatically and stays on for 30 minutes.
  3. Time-Based Brightness: The lights adjust their brightness based on the time of day—brighter during the day and softer in the evening.
Challenges and Solutions:
  • Integration: I had to figure out the right sensors and dimmers that are compatible with my smart hub. After some research, I found a reliable UK-based brand that works seamlessly with my system.
  • Automation Logic: Getting the timing and brightness levels just right took a bit of trial and error, but now it works perfectly!
Why I Love It:
This setup has made my bathroom incredibly convenient. I no longer have to manually turn lights or the fan on—it all happens automatically. Plus, it’s energy-efficient since everything turns off when not in use.
Tips for Others:
  • Start small and test each component before setting up the full automation.
  • Use a smart hub that supports multiple protocols to ensure compatibility with different devices.
  • Don’t be afraid to tweak your rules over time to make everything work perfectly for your lifestyle.
I’m really happy with how this project turned out, and I hope it inspires others to try similar smart home automations! Let me know if you have any questions or suggestions. :blush:
