Creating a Smart Morning Routine with Automation
Hi all, I wanted to share my experience in creating a smart morning routine using automation. I’ve been experimenting with setting up my home to wake me up gently and prepare my space for the day ahead. It’s been a fun project and I’d love to hear how others approach similar automations!
My goal was to create a seamless transition from sleep to wakefulness. I decided to incorporate a few key elements: adjusting the lighting, controlling the temperature, and ensuring my coffee maker starts brewing. Here’s how I did it:
  1. Lighting Adjustment: I use a combination of smart bulbs and a light strip. The automation starts by gradually increasing the brightness of my bedside lamp over 15 minutes. This mimics natural sunlight and helps me wake up more naturally. I also set my bathroom lights to turn on at full brightness once the alarm goes off, ensuring I’m greeted with enough light to start my day.
  2. Temperature Control: I have a thermostat that I’ve integrated into the routine. It begins by slightly increasing the temperature 30 minutes before my alarm goes off, ensuring the room is comfortably warm when I wake up. This has been especially helpful during colder months.
  3. Coffee Brewing: One of the best parts of my morning routine is waking up to the aroma of freshly brewed coffee. I set my smart coffee maker to start brewing 10 minutes before my alarm goes off. It’s a small touch, but it makes a big difference in how I start my day.
  4. Alarm System: I use a smart speaker for my alarm. It’s set to play soft, uplifting music at a gradual volume increase to ensure I’m not startled awake. The speaker also provides a daily weather update and a quick news briefing, giving me a heads-up on the day’s plans.
Challenges and Solutions:
  • Timing: Finding the right timing for each element was tricky. I had to experiment with different intervals to ensure everything happened at the optimal time without overlapping or causing disruptions.
  • Integration: Ensuring all devices worked together seamlessly required some trial and error. I had to check compatibility and make sure all devices were correctly paired with my hub.
Tips for Others:
  • Start small. Begin with one or two devices and gradually add more as you become comfortable.
  • Use templates or pre-built routines if available. Many platforms offer starter automations that can be customized to fit your needs.
  • Don’t hesitate to tweak your settings. What works one day might need adjustment based on your changing schedule.
I’d love to hear how others have set up their morning routines. What devices do you find most helpful? Have you encountered any unique challenges or found innovative solutions? Let’s share and inspire each other!
Cheers,
