Hi everyone,
I’d be curious about how the automations you can create with a door bell and presence sensor from Aqara and several light from Philips Hue. Apart from the latest version of the HomePod, I also got an Aqara hub as well as a hub from Philips. I’m not quite sure about the best way to set up automations.
Thnx for sharing your ideas!
@a_stern Hi there! It’s great to see you diving into the world of smart home automation with such a versatile setup. Mixing Aqara sensors with Philips Hue lights via HomeKit is a popular choice for creating seamless, voice-controlled experiences.
Based on your setup, here are a few ways to approach your automations:
1. Leveraging the Aqara Hub and HomeKit Bridge
If you want to use your Aqara Presence Sensor (like the FP2) or Door Bell to trigger Philips Hue lights, the most reliable method within the HomeKit ecosystem is often to let the Aqara Hub act as the bridge.
- Setup: Ensure your Aqara devices are connected to the Aqara Home App and linked to HomeKit. The Aqara Hub acts as a Matter bridge or HomeKit bridge, allowing you to see these devices in the Apple Home app.
- Automation: You can then create an automation in the Apple Home app: “If Aqara Presence Sensor detects motion, then turn on Philips Hue Lights.” This keeps everything unified under one HomeKit interface, leveraging the HomePod for voice control.
- Note: Some advanced Aqara-specific automations (like specific presence zones) might only work within the Aqara Home app. If you need complex logic that HomeKit doesn’t support natively, you might need to create the automation in the Aqara Home app and ensure the target lights are also controllable from there, or use a service like Home Assistant for deeper integration.
2. Using Aqara’s Native Automation Templates
The Aqara Home app offers robust automation templates that can be quite powerful.
- Presence Sensor: You can set up automations like “When FP2 detects a person, turn on the light” or even more advanced scenarios where lights turn on only near the person and off when they leave the area.
- Door Bell: You can trigger actions when the doorbell rings, such as turning on lights or playing a sound.
- Tip: Check if your Philips Hue lights are also paired with the Aqara Home app (if they are Zigbee or Matter-compatible via a compatible hub). If they are, you can trigger them directly from Aqara automations. If not, sticking to HomeKit automations is usually the smoother path for third-party lights.
3. Philips Hue Hub Integration
Since you have a Philips Hue hub, you can also create automations directly within the Philips Hue app or via HomeKit using the Hue hub as the controller.
- HomeKit Integration: Make sure your Philips Hue hub is added to the Apple Home app. Then, you can use Aqara sensors (if they are also in the Home app) as triggers for Hue lights.
- Alexa/Google Home: If you use other smart speakers, you can link both hubs to Alexa or Google Home and create routines there.
Recommendation:
For the cleanest experience with a HomePod, I’d recommend adding both the Aqara Hub and Philips Hue Hub to the Apple Home app. Then, create automations in the Home app. This allows you to use Siri on your HomePod to control everything and ensures that when the Aqara sensor triggers, the Hue lights respond immediately within the HomeKit ecosystem.
If you run into any specific pairing issues or want to explore more advanced Aqara-specific features (like using the Cube or specific door lock automations), feel free to ask!
Happy automating!
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
