Cube T1 Pro - Automatizations HAOS + Aqara APP
Hi,
What kind of cool automations can you guys recommend I do with this device using HAOS / Aqara APP?
Thank you,
@jcgiraldoh1 The Cube T1 Pro is a pretty versatile little controller with tons of gesture options to play with! In the Aqara Home app, you’ve got two modes to work with: Action Mode (flip 90°/180°, shake, tap twice, push, rotate) and Scene Mode (six face-up states plus rotate, pick up & hold, shake per face) — totaling up to 70 different automation combinations.
Here are some fun, practical automation ideas to get you started:
Lighting Control
  • Rotate to dim/brighten lights (great for movie nights)
  • Flip 90° to toggle a lamp, flip 180° for all-room lights
  • Face 1 up = warm white, Face 2 up = cool white (Scene Mode)
Entertainment
  • Shake to start your “gaming mode” scene (lights dim, RGB strips on)
  • Pick up & hold to pause music or mute TV
Daily Routines
  • Face 3 up = morning routine (curtains open, coffee reminder)
  • Face 4 up = bedtime (lights off, thermostat down, security armed)
  • Triggered after one-minute inactivity = auto-lock door or turn off idle devices
Security/Peace of Mind
  • Push gesture = panic button, flash lights + send notification
  • Specific face-up states for family members to trigger personalized scenes
Since you’re running HAOS too, you can bridge the best of both worlds — use Aqara’s native automations for low-latency local control, and HA for more complex logic, conditions, or integrating non-Aqara gear. The Cube exposes well in HA via Zigbee2MQTT or ZHA, so those face-up states and gestures become entities you can use in Node-RED or YAML automations.
What devices are you already working with? Happy to brainstorm more tailored setups
Hey there.well I have no knowledge about HAOS but on Aqara home app you can chose to control devices or scenes with it. I personally use it to control 2 scenes and some Aqara devices and if you have many devices on an room you can control them with this Magic Cube this way you do not need to take your phone to run an device/scene or do different type of automations to run such devices
Thank you, I hadn’t thought about adding a delay for bed time to let you leave the room but I should have. :slightly_smiling_face:
I will implement this very soon.
@mark_rogers_oakdene Glad that clicked for you! The bedtime delay is one of those “why didn’t I think of that sooner” moments with the Cube T1 Pro. Since you’re already running HAOS alongside Aqara, you’ve got some nice options for how to implement it.
A couple of ways to approach the exit delay depending on where you want the logic to live:
In Aqara Home — pair your “Face 4 up = bedtime” automation with the alert system’s delayed arming concept. Your Cube triggers a countdown, giving you time to leave before the security mode kicks in and lights finish their shutdown sequence.[“content_id”:0"]
In Home Assistant — use a delay or timer helper in your YAML/Node-RED flow. This lets you get fancier: maybe the hallway light stays on for 90 seconds at 20% brightness, then your Aqara security arms via the Aqara integration. HA’s better for these conditional, multi-step sequences.
Hybrid approach — Aqara handles the low-latency light/thermostat changes, HA manages the delayed lock/arm logic and sends you a confirmation notification. Best of both worlds.
Pro tip: if you’ve got motion sensors in that exit path, you can use them as a “dead man’s switch” — motion detected extends the delay, no motion means proceed with arming. Keeps it forgiving if you forgot something and double back.
What room layout are you working with? Happy to help sketch out the timing if you want to get precise about it.
A few that work well with the T1 Pro in Home Assistant:
  1. Rotate to change the volume of the speaker in the room. The rotation angle comes with the event, so you can make it smooth.
  2. In scene mode, each face up is a scene: movie, reading, everything off.
  3. Shake to run a “leaving” routine: lights off, heating down, and a check that the doors are closed.
  4. Double tap to toggle the main light, for the guests who don’t know the rest.
One tip: put a small sticker with the face numbers, at least the first weeks. If not, the family gives up on it fast.
