Hello everyone, I wanted to share my experience with setting up a custom background image on my FHZ 1300. I recently designed a floor plan using a graphics program and uploaded it as the background image on my web interface. However, I encountered an issue where the image appeared four times next to each other and twice below. After some research and trial and error, I found a solution that worked for me!
The Problem:
When I uploaded my custom background image, it didn’t display correctly. Instead of showing the image once, it appeared multiple times, which was quite confusing.
The Solution:
I discovered that the issue was related to how the image was positioned within the web interface. By adjusting the CSS settings in the background image configuration, I was able to center the image and ensure it only appeared once. Here’s how I did it:
Upload Your Image:
- Navigate to the settings in your FHZ 1300 web interface.
- Go to the background image section and upload your custom image.
Adjust CSS Settings:
- After uploading, look for CSS or positioning settings within the background image configuration.
- Set the position to ‘center’ and adjust the width and height to fit your screen perfectly.
Save and Refresh:
- Save your changes and refresh the web interface to see the updated background.
Result:
My custom background image now displays correctly, centered on the screen without any duplication. It looks great, and I can easily navigate my smart home controls with the custom layout I designed.
I hope this helps anyone else who might be struggling with custom background images on their FHZ 1300. Happy customizing! ![]()
