I’ve been experimenting with customizing the visual aspects of my Home Assistant setup, and I’m thrilled to share my latest achievement! I’ve successfully implemented dynamic badge colors for my temperature sensors, which automatically adjust based on the temperature readings. This enhancement not only makes monitoring easier but also adds a touch of personalization to my dashboard.
The journey began with my desire to make the temperature indicators more intuitive. Instead of static colors, I wanted them to reflect the actual temperature values dynamically. After some research, I came across a solution that uses a combination of card-mod and mod-card to style the badges. The process involved creating a custom Jinja template that maps temperature values to specific colors using linear interpolation in the RGB space.
Here’s a brief overview of how I implemented it:
- Custom Template Creation: I created a
dynamic_colors.jinjafile that defines temperature ranges and corresponding colors. This allows for smooth transitions between predefined color stops. - Card Configuration: I configured my badges to use the
custom:hui-entity-badgecard type and wrapped them withmod-cardto enable styling through card-mod. - Styling: Using card-mod, I applied the dynamic color logic to both the state text and the icon, ensuring a consistent and visually appealing representation.
The result is nothing short of impressive. Whether I’m using a light or dark theme, the badges now provide a clear and visually intuitive representation of the temperature. This customization has significantly improved my monitoring experience, making it both functional and aesthetically pleasing.
I’d love to hear from others who have undertaken similar projects or have suggestions for further enhancements. How have you personalized your Home Assistant setup? Any tips or tricks to share would be greatly appreciated!
