Hey everyone! I wanted to share my recent project where I set up custom fan speed controls in Home Assistant. It’s been a fantastic learning experience and I’m really happy with the outcome. Here’s how I did it:
The Goal
I have a few ceiling fans throughout my house and I wanted a more intuitive way to control their speeds. The default fan controls in Home Assistant are functional, but I was looking for something more visually appealing and user-friendly.
The Solution
I stumbled upon a custom UI element called state-card-custom-fanspeed on GitHub. It allows you to create a sleek, button-based interface for controlling fan speeds. The setup was surprisingly straightforward once I broke it down into steps.
Setup Steps
Install Custom UI
- First, I made sure that the Custom UI integration was installed and enabled in my configuration. This was a quick process through the frontend settings.
Download the Fan Speed Card
- I downloaded the
state-card-custom-fanspeed.htmlfile from the GitHub repository and saved it in mywww/custom_uidirectory on my Raspberry Pi.
- I downloaded the
Update Configuration
- I added the necessary lines to my
configuration.yamlfile to enable the custom fan speed card. This involved specifying the card under thefrontendsection and ensuring it was properly linked.
Test and Refine
- After restarting Home Assistant, I tested the new fan controls. I had to do a hard refresh of the interface (Shift + F5) to ensure the changes were applied. Everything worked perfectly on the first try!
Results
Now, each of my fans has a clean, four-button interface (Off, Low, Medium, High) that’s easy to navigate. The buttons even change color based on the current fan speed, providing clear visual feedback. It’s such a small touch, but it makes a big difference in the overall user experience.
Tips for Others
- If you’re new to custom UI elements, don’t be intimidated. The community has done an amazing job making these resources accessible.
- Make sure to back up your configuration before making changes. It’s a simple precaution that can save a lot of hassle.
- Don’t hesitate to reach out to the community if you run into any issues. The forums are incredibly supportive and there’s always someone willing to help.
This project was a great way to dive deeper into Home Assistant’s customization capabilities. It’s amazing how a small tweak can make such a positive impact on your daily interactions with your smart home. I’m already brainstorming my next project—maybe something with my lighting setup!
Thanks to everyone who contributed to the state-card-custom-fanspeed project. Your work really enhances the Home Assistant experience!
Cheers,
