Hello Vera Lite enthusiasts! I wanted to share my journey and tips on setting up custom scripts for Vera Lite. Over the past few months, I’ve been working on automating various aspects of my home, and while the process has been rewarding, it hasn’t been without its challenges.
One of the first things I learned was the importance of understanding the difference between polling and triggering. Polling, which involves making regular API requests to check sensor data, is straightforward but can be resource-intensive, especially with devices like motion sensors that require quick responses. On the other hand, using the GUI to set up triggers seems more efficient as it listens for events rather than constantly checking.
I found that for motion sensors, relying on the GUI to trigger actions was much smoother and faster than writing scripts that polled every second. However, for devices like temperature sensors where real-time data isn’t as critical, polling every minute or so works perfectly fine.
Another tip I’d like to share is about optimizing your scripts. I initially tried to handle everything through custom scripts, which led to some performance issues. By combining custom scripting with Vera’s built-in automation features, I was able to achieve a balance that improved system responsiveness.
If you’re new to scripting, I recommend starting with simple tasks and gradually building up complexity. Also, don’t hesitate to look into Vera’s documentation and community forums for guidance. Every script I’ve successfully implemented has taught me something new and has made my home automation setup that much better!
Happy scripting everyone! ![]()
