I’ve been trying to create a custom weather card in Home Assistant for weeks now, and I’m thrilled to finally share my success story! ![]()
For those of you who might be in the same boat, I want to walk you through my journey. I started off completely clueless about coding, but I knew I wanted a weather card that could display all my sensor data in one neat place. I have sensors for temperature, humidity, rain, and even a 5-day forecast—so much data, but no way to visualize it neatly!
I stumbled upon the bom-weather-card while searching for solutions, but getting it to work was an absolute nightmare. Nothing seemed to show up, and I was pulling my hair out trying to figure out what I was doing wrong. Frustration aside, I refused to give up!
After days of tinkering and endless Google searches, I finally found a solution that worked for me. I ended up using a combination of built-in cards and a bit of YAML magic to create a card that not only looks great but also displays all my sensor data in a way that’s easy to read. The best part? I didn’t need to write a single line of code—just some careful configuration!
Here’s a quick tip for anyone else struggling with custom cards: start simple. Add one sensor at a time and test it before moving on. It might take longer, but it’s much less frustrating than trying to debug everything at once.
If you’re still stuck, feel free to reach out! I’d love to help you create your perfect weather card. ![]()
Happy automating! ![]()
