Hey everyone, I’ve been diving into the world of customizing my smart devices, and I wanted to share my experiences and tips with you all. One thing that’s always bugged me is the default status names that come with some devices. For instance, my robot lawn mower shows “cleaning” when it’s actually “mowing.” It might seem minor, but having accurate status names makes the whole setup feel more polished and user-friendly. So, I decided to figure out how to change these status names myself.
I stumbled upon the custom:mushroom-vacuum-card add-on, which allows you to display the status of your devices. While it works perfectly, I was determined to tweak the status names to better reflect what was happening. After some research, I found that many devices allow you to modify these names through their configuration files or by using third-party apps. For example, I was able to change “cleaning” to “mowing” by editing the JSON configuration file of my mower’s card. It wasn’t too complicated once I knew where to look!
But not all devices are as straightforward. Some might require a bit of coding or even reaching out to the manufacturer for support. I’ve heard that certain devices, like the Eufy video doorbell, can be integrated into platforms like Hubitat, which gives you more control over their settings and status names. It’s all about exploring the options and finding what works best for your setup.
Another tip I’ve picked up is to use MQTT for more advanced configurations. By setting up MQTT topics, you can send custom status updates to your devices or home automation hub. This method is especially useful if you’re into DIY projects or have multiple devices that need consistent naming across your system.
I’d love to hear how others have tackled this issue. Have you successfully customized status names on your devices? What tools or methods did you find most helpful? Let’s share our experiences and tips to help each other out!
Cheers,
