Hi everyone! I’ve been working on customizing the colors of my temperature sensors in Home Assistant, and I wanted to share my journey and solution with you.
The Challenge
I wanted to color both the icon and the value of my temperature sensors based on different temperature ranges, while keeping the name in its standard color. Initially, I struggled with the fact that changing the color for the icon also affected the value and name. After some research and experimentation, I found a way to achieve the desired effect.
My Solution
Here’s the code I ended up using:
yaml
- entity: sensor.aussenmodul_temperature
icon: mdi:temperature-celsius
card_mod:
style: |
:host {
–card-mod-icon-color: {% if states.sensor.aussenmodul_temperature.state | int <= 3.0 %} deepskyblue
{% elif states.sensor.aussenmodul_temperature.state | int <= 12.0 %} darkcyan
{% elif states.sensor.aussenmodul_temperature.state | int <= 20.0 %} olivedrab
{% elif states.sensor.aussenmodul_temperature.state | int <= 25.0 %} goldenrod
{% elif states.sensor.aussenmodul_temperature.state | int <= 30.0 %} peru
{% elif states.sensor.aussenmodul_temperature.state | int > 30.0 %} coral
{% endif %};
.value {
{% endif %};
Explanation
- Icon Color: The
--card-mod-icon-colorvariable is used to set the icon color based on the temperature range. - Value Color: The
.valueclass is targeted to set the color of the temperature value independently. - Name Color: The name remains in its default color as it’s not explicitly targeted in the style.
Outcome
This setup allows me to have a visually consistent and informative dashboard where the icon and value colors change based on temperature, while the name stays consistent. It’s been a great way to quickly assess the temperature at a glance!
I hope this helps someone else looking to customize their temperature sensors in Home Assistant. Happy automating! ![]()
