Hi everyone! I’m really excited to share my experience with integrating the Danfoss Link system into my OpenHAB setup. I’ve been working on upgrading my home heating system, and I wanted something that could seamlessly integrate with my existing smart home ecosystem. After some research, I decided to go with the Danfoss Link system, which includes the Danfoss Link™ CC, RS, Connect, HC Master, and Gateway, along with the Danfoss ECL 110 controller.
The system is controlled via the Danfoss app, which works perfectly on iOS. However, my main goal was to have full control over this system through OpenHAB. I knew this would require some digging into bindings and configurations, but I was up for the challenge!
One of the first things I discovered was that there isn’t an official OpenHAB binding for Danfoss Link. This meant I had to get creative. I found that the system communicates over a serial interface, which led me to explore using the Serial Binding in OpenHAB. After some trial and error, I managed to establish a connection between the Danfoss Gateway and my OpenHAB instance.
The next step was figuring out the right commands to send to the system. I spent a lot of time reverse-engineering the communication protocol and testing different commands. It was a bit frustrating at times, but the satisfaction of seeing everything work together made it all worth it!
I also reached out to the OpenHAB community for advice, and I was pleasantly surprised by how helpful and supportive everyone was. Someone mentioned using the MQTT Binding as an intermediary, which turned out to be a game-changer. By setting up MQTT topics for temperature readings and control commands, I was able to create a smooth integration that allows me to control my heating system directly from OpenHAB.
Here are a few tips I’ve learned along the way:
- Documentation is key: Make sure to thoroughly document every step of your setup. This will save you a lot of time if you need to troubleshoot later.
- Community support: Don’t hesitate to ask for help. The OpenHAB community is incredibly active and willing to assist.
- Start small: Begin with a single component, like temperature monitoring, before moving on to full control. This phased approach makes it easier to identify and fix issues.
I’m now able to control my heating system through the OpenHAB interface, set up rules for energy-efficient heating, and even integrate it with my voice assistant for hands-free control. It’s been a fantastic journey, and I’m so glad I took the plunge into this project.
If anyone else is looking to integrate their Danfoss Link system into OpenHAB, I’d be happy to share more details or help troubleshoot any issues you might encounter. Let’s keep the conversation going and help each other create smarter homes!
Cheers,
