Hey everyone!
I wanted to share a quick tip that might help some of you out there who are struggling with debugging issues in your smart home setup. I recently stumbled upon a clever way to make debugging easier and more visual, and I thought Iād pass it on!
So, hereās the deal: I was having some trouble with a service not working as expected. After some digging, I realized that the issue was related to how I was extracting a specific value from an object ID. I was using a lazy method that wasnāt quite reliable, and it was causing some confusion. Instead of getting frustrated and sending endless messages to my phone (which I totally get why someone would do that), I decided to try something different.
I came across the idea of using persistent notifications. The concept is pretty simple: instead of relying on logs or messages that might get lost in the noise, you create a notification that sits right there in the ābellā icon at the top of your screen. Itās like having a little helper that keeps you in the loop without you having to constantly check things.
Hereās how I set it up:
yaml
- service: persistent_notification.create
data_template:
title: āLOCK MANAGERā
message: >-
{% set object_id = trigger.to_state.object_id %}
{% set codeslot = object_id[15:] %}
{{ 'You changed the PIN for code ā + codeslot | string + ā. Please enable it in order to make it active.ā}}
This little snippet helped me identify the exact issue by clearly showing the codeslot value. It was a game-changer because it allowed me to see exactly where things were going wrong without having to dig through logs or send endless notifications.
What I love about this method is how straightforward it is. Itās perfect for those moments when youāre trying to figure out why something isnāt working, and you need a clear, visual reminder of whatās happening. Plus, itās a great way to keep track of actions that require follow-up, like enabling a new PIN code.
If youāre dealing with similar issues, I highly recommend giving persistent notifications a try. Itās a small tweak that can make a big difference in how you troubleshoot and manage your smart home setup. Let me know if youāve found other creative ways to simplify debuggingāIām always looking for new tips and tricks!
Happy automating! ![]()
