Detecting Non-IoT Gas Grills with Home Assistant
Earlier this year, I stumbled upon an ingenious solution to monitor my non-IoT gas grill using Home Assistant. The idea, originally conceived by Mahko_Mahko, involves using a simple reed sensor—a component typically used to detect open doors—to monitor the gas knob on my grill. This setup allows me to track whether the grill is on or off, eliminating the worry of accidentally leaving the gas open while away from home.
The process was surprisingly straightforward. I attached the reed sensor to the gas knob, ensuring it detected when the knob was turned. I then integrated this sensor into Home Assistant, setting up notifications to alert me if the grill was left on. This solution not only provides peace of mind but also adds a layer of safety to my outdoor cooking setup.
I’d like to share this method with anyone else who might be interested in monitoring their grill without investing in a fully IoT-enabled model. It’s a testament to the versatility of Home Assistant and the creativity of its community. If you’re curious about the exact steps or have questions about the setup, feel free to reach out!
Cheers to innovative problem-solving and safe grilling! :hamburger::fire:
