Hi everyone, I wanted to share a tip that might be helpful for those of you using panic buttons in your smart home setup. I recently installed some 2GIG panic buttons in different rooms around my house, and while they work great, I noticed that the panel would announce the voice descriptor for the button (like ‘Panic remote ***’) before sounding the alarm. This got me thinking - if someone were in another part of the house and pressed the panic button, hearing the panel announce it might not be ideal.
After some research and experimentation, I found that it’s actually possible to disable this voice announcement feature. Here’s how I did it:
- Access the Settings: Go to your security panel’s settings menu. Depending on your model, this might be under the ‘User Settings’ or ‘Configuration’ section.
- Locate the Voice Announcement Option: Look for an option related to voice announcements or verbal notifications. This might be under a submenu like ‘System Settings’ or ‘Notification Preferences’.
- Disable the Feature: Once you find the voice announcement setting, simply toggle it off. This will prevent the panel from announcing the panic button press.
- Test the Setup: After making the change, test the panic button to ensure the alarm sounds without the voice announcement. This gives me peace of mind knowing that the system will still trigger the alarm effectively while maintaining privacy.
I hope this tip helps others who might be looking to fine-tune their panic button setup. If anyone has additional questions or experiences to share, I’d love to hear about them! Happy smart home tweaking! ![]()
