After years of trial and error, I finally found a smart dimmer that ticks all the boxes for my UK home setup. The Varilight Eclique 2 has been a game-changer for me, offering seamless integration with my smart home system. Here’s why I love it:
- Traditional Switch Feel: It operates just like a standard dimmer switch, providing that familiar tactile feedback.
- Versatile Design: Available in multiple finishes (Classic, ScrewLess, UltraFlat) and colors, it blends seamlessly with any decor.
- Reliable Performance: Smooth dimming without flickering, and it works perfectly with LED bulbs and multiple GU10s.
- No Neutral Wire Needed: A direct replacement for existing 2-wire switches, no complicated rewiring required.
- Smart Integration: While it doesn’t natively support smart home systems, I created a small device to bridge the gap, allowing control via ZigBee.
The Eclique 2 also supports up to 4 light groups and 4 scenes, giving me flexibility in how I control my lighting. For example, I can set different brightness levels for each group and recall them with a simple button press or via my smart home app.
To enhance its smart capabilities, I developed a tiny device that plugs into the same room, enabling control through my ZigBee setup. This means I can adjust the lights using my voice or through my smart home app, without needing to use the physical switch every time.
If you’re looking for a dimmer that combines the best of traditional and smart features, I highly recommend the Varilight Eclique 2. It’s been a reliable and elegant solution for my home, and I’d love to hear if anyone else has tried it or has similar setups!
Would love to hear if others are interested in the device I created for integration!
