DIY Camera Battery Fix and Smart Thermostat Setup
Hey everyone, I wanted to share a couple of projects I’ve been working on lately. First, I’ve been dealing with some camera battery issues. The batteries in my Wyze cameras were only lasting about a month, which was a huge inconvenience. After some research, I discovered that the metal contacts inside the battery compartment were loose, causing poor connections. I decided to fix this myself by carefully soldering the contacts to ensure a better connection. It worked like a charm! Now, my cameras are lasting much longer, and I’ve saved a lot of money on batteries. If anyone else is having similar issues, I’d be happy to share more details on how I fixed it.
On another note, I’ve been working on setting up my Nest thermostat with a Heat Link. It was a bit of a challenge at first, especially since I had to factory reset the thermostat after returning from vacation. I kept getting an error message when trying to generate an entry code. After some troubleshooting, I realized the issue was with the Heat Link box. I had to reset it and make sure it was properly connected to the thermostat. Once everything was aligned, the setup went smoothly. I’m now enjoying the convenience of controlling my thermostat through the Nest app.
If anyone has questions about these projects or needs advice on similar issues, feel free to reach out. I’m always happy to help out the community and share what I’ve learned!
