DIY Car Security System: A Comprehensive Setup Guide
Recently, I embarked on a DIY project to create a car security system that would provide me with peace of mind while my vehicle was parked away from home. After some research and experimentation, I successfully set up a system that combines several affordable and readily available components. I’d like to share my setup in case others are looking for a similar solution!
Supplies Used
  1. Portable Car Jump Starter: I opted for the BEATIT G18 QDSP 2000Amp model. It’s compact, powerful, and has a built-in LED light, which is a nice bonus.
  2. Waze Cam 1: This dash cam was the perfect choice for its high-resolution video quality and ease of use.
  3. Old Smartphone: I used an old iPhone 6 that was lying around. It served as a Wi-Fi hotspot, which was essential for connecting the camera to my network.
  4. USB Switch: The Onite 2pcs Micro USB Female to Male Cable Raspberry Pi 3, Pi 2, B+, Zero W Power Switch Cord was a game-changer. It allowed me to control the power supply to the camera, ensuring it only turns on when needed.
  5. Industrial Velcro: This was used to securely mount the camera on my windshield without causing any damage.
Setup Process
  1. Power Management: I connected both the jump starter and my phone to the car’s electrical system. This ensures they stay charged while the car is running, avoiding any drain on the battery.
  2. Camera Installation: Using the industrial velcro, I mounted the Waze Cam on the windshield. The USB switch was then connected to the jump starter, allowing me to control the camera’s power supply.
  3. Wi-Fi Hotspot Setup: I set up the old iPhone as a Wi-Fi hotspot. This created a local network that the Waze Cam could connect to.
  4. Camera Configuration: Using another smartphone with the Wyze app, I added the camera to my network by connecting to the hotspot. This was a straightforward process, and I was up and running in no time!
Outcome and Benefits
This setup has been a fantastic addition to my car security. The Waze Cam provides high-quality recordings, and the ability to monitor it remotely through the Wyze app gives me peace of mind. The USB switch ensures that the camera only consumes power when it’s actively in use, which helps conserve battery life.
Tips and Tricks
  • Power Management: Ensure all devices are properly connected to the car’s electrical system to avoid any unexpected battery drains.
  • Secure Mounting: Use high-quality adhesives or velcro to secure the camera without causing damage to your windshield.
  • Regular Checks: Periodically check the camera’s connectivity and app settings to ensure everything is functioning as expected.
If you’re looking for a cost-effective way to monitor your vehicle while it’s parked, I highly recommend giving this DIY setup a try! It’s been a lifesaver for me, and I hope it can provide similar peace of mind for others.
Happy tinkering! :red_car::sparkles:
