Hey all, just wanted to drop in and share a little weekend win I had that might help some of you trying to mix and match gear across platforms.
I’m what you’d call a smart home tinkerer—not quite a pro, but definitely addicted. I’ve been deep into the Aqara ecosystem for a while now (got the M2 Hub as my main brain), but I had a few non-Aqara Zigbee sensors lying around from older setups. Instead of letting them collect dust, I decided to see if I could bring them into the Aqara fold.
Surprisingly… it worked. With a bit of trial and error.
So here’s the setup: M2 Hub as the base, used Home Assistant (running on a Pi) as the glue. I bridged some old IKEA and Sonoff sensors via Zigbee2MQTT, and then used HomeKit as a sort of common language between them all. Bit clunky at first, but once it clicked, everything just worked.
Now I’ve got motion sensors triggering Aqara scenes, and even a random door sensor from god-knows-where automating lights. The key was keeping everything local and latency low.
Moral of the story: don’t toss your old gear just yet. With some patience and the right integrations, Aqara can play pretty nicely with others—even stuff that wasn’t “meant to.”
Anyone else tried something similar? Curious how far people have pushed integration with the M2.
Let’s nerd out.
