Hi everyone! I wanted to share a few experiences and tips I’ve gathered recently while working on my smart home setup. Whether you’re a seasoned pro or just starting out, I hope this helps someone out there!
DIY LED Ice Cream Cone Art
First off, I’ve been absolutely thrilled with my recent DIY project—an LED-lit ice cream cone! It’s a fun way to add a touch of whimsy to any room. I used RGBW LED flex bands for the lighting, which allowed me to set it to different colors and brightness levels. The setup was pretty straightforward, and it’s been a hit with everyone who sees it. If you’re into DIY projects, I highly recommend giving this a try!
Fixing an Automation Script
On the technical side, I ran into an issue with an automation script I set up for my living room lights. The script was supposed to turn the lights on at sunset, but they’d turn off after just a second. After some troubleshooting, I realized the issue was with the timing offset in the automation. I adjusted it to trigger a bit earlier, and now everything works like a charm! If you’re having similar issues, double-check your triggers and offsets—they can make a big difference.
Schlage Door Lock Setup
Lastly, I wanted to talk about my Schlage door lock setup. I’ve been using it for a while now, and it’s been a reliable addition to my smart home. One thing I learned is that setting up PIN-only access for specific times of day requires a bit of trial and error. I also noticed some error messages in the logs, but the lock itself has been functioning perfectly. If you’re setting up a Schlage lock, make sure to test all your PINs and access times thoroughly during installation.
Overall, working on these projects has been a great learning experience. I love how smart home technology allows for both creativity and practicality. If anyone has questions or wants more details on any of these topics, feel free to ask!
Happy tinkering everyone! ![]()
