Hello everyone! I wanted to share my recent DIY lighting project using the Govee RGBIC Pro LED Strip Lights. It’s been a fantastic way to add some personality to my home while experimenting with smart lighting solutions. Here’s how it all came together!
Project Overview
I decided to upgrade my living room lighting by adding RGBIC strips to create a dynamic ambiance. The goal was to combine functionality with aesthetics, ensuring the lights could be easily controlled via my smartphone and integrated into my existing smart home ecosystem.
Materials Used
- Govee RGBIC Pro LED Strip Lights (49.2ft)
- Light strip diffuser brackets
- PVC crown molding
- Screws and drill
- Circular saw
Installation Process
- Planning the Layout: I started by measuring the ceiling to determine where to place the crown molding. The key was to position the lights about an inch from the wall to create a subtle, elegant effect.
- Cutting and Drilling: Using a circular saw, I cut the PVC molding to fit the ceiling. Pre-drilling screw holes every 18 inches ensured the molding wouldn’t sag and helped prevent light leakage.
- Mounting the Molding: I carefully attached the molding to the ceiling, ensuring it was level. This step required some patience to get everything aligned perfectly.
- Installing the LED Strips: The Govee strips were easy to install. I adhered them to the underside of the molding and connected them to my smart home hub using the Govee app.
- Testing and Customization: Once everything was in place, I used the Govee app to test different color settings and brightness levels. It was amazing to see how the lights transformed the room!
Challenges and Solutions
One challenge I faced was ensuring the lights were evenly distributed. I solved this by using a level and measuring tape to space the molding evenly. Another consideration was preventing any light spill, which I managed by using black electrical tape on the unseen side of the molding.
Results and Benefits
This project has completely changed the look of my living room. The RGBIC lights allow me to set the mood for any occasion, from cozy evenings to vibrant parties. Plus, the energy efficiency of LED strips means I’m saving on electricity costs.
Tips for Others
- Plan Ahead: Spend time measuring and planning to ensure everything fits perfectly.
- Use Quality Tools: A good saw and drill make a big difference in the installation process.
- Experiment with Colors: Don’t be afraid to try different color settings to find what works best for your space.
I hope this project inspires others to try their own DIY lighting projects with Govee products. It’s been a rewarding experience, and I’m excited to see how I can expand this setup in the future!
Cheers,
