Hi everyone,
I wanted to share my recent project where I built a DIY microwave sensor to integrate with my smart home setup. It’s been a fun and challenging journey, and I’d love to hear your thoughts or tips!
The Problem:
I have a corridor with an insulated glass window door, and I wanted to trigger my camera (either Arlo or Blink) when motion is detected. The challenge was that the corridor doesn’t have access to power sockets, and normal battery-powered PIR sensors don’t work through glass. Plus, I couldn’t install anything on the opposite side of the glass.
The Solution:
I decided to build a DIY microwave sensor that could detect motion and activate my camera. The sensor needed to be battery-powered with minimal delay. After some research, I started exploring whether to use an Arduino or Raspberry Pi. I chose the Raspberry Pi because of its processing power and ease of integration with my existing smart home ecosystem.
The Build:
I sourced a microwave sensor module and connected it to my Raspberry Pi. I wrote a Python script to detect motion and send a signal to my camera. The script also handles battery monitoring and ensures minimal delay for real-time activation.
Integration with SmartThings:
One of the best parts was integrating this with SmartThings. I created a custom device handler to communicate with my Raspberry Pi and trigger the camera. It’s amazing how seamlessly everything works together now!
Lessons Learned:
- Power Management: Battery life is crucial, so I optimized the sensor to only wake up periodically.
- Signal Stability: Ensuring a stable microwave signal through glass was tricky but doable with the right components.
- Scripting: Learning Python was a great side benefit and has opened up更多 possibilities for future projects.
Next Steps:
I plan to expand this project by adding more sensors in different areas of my home. I’m also considering integrating this with my OpenHAB setup for even more automation possibilities.
If anyone has tips on improving the sensor’s range or reducing power consumption, I’d love to hear them! This project has been a fantastic way to learn more about DIY electronics and smart home integration.
Cheers,
