DIY Multi-Sensor Setup with ESPHome - Success Story!
Hey everyone, I wanted to share my recent project with you all! After months of research and planning, I finally built my own multi-sensor device using ESPHome and an ESP8266 board. It’s been a fantastic learning experience, and I’m thrilled with the results!
Project Overview
I decided to create a sensor that could monitor temperature, humidity, light, CO2 levels, and motion—all in one compact unit. The goal was to have a self-contained device without the need for frequent battery changes. I’ve always been a fan of DIY projects, and this one was particularly rewarding.
Components Used
  • DHT22: For temperature and humidity sensing.
  • AM312: Motion detection capabilities.
  • MH-Z19C: CO2 sensor for air quality monitoring.
  • TEMT6000: Ambient light sensor.
Assembly Process
I 3D printed the enclosure myself, which was a great way to customize the design. I opted for a sleek black finish, but I also created a white version for those who prefer a more subtle look. The wiring was straightforward, and I included a detailed diagram in my notes for anyone interested in replicating the project.
ESPHome Configuration
Configuring the ESPHome platform was a breeze. I set up the sensors to update every minute, ensuring real-time data. The CO2 sensor was a particular highlight—it’s incredibly accurate, and the automatic baseline calibration feature is a lifesaver.
Integration and Results
I integrated the device into my Home Assistant setup, and it’s been running smoothly ever since. The temperature offset for the DHT22 was a minor tweak, but once adjusted, everything worked like clockwork. The device is now connected to my router’s USB port, freeing up valuable outlets.
Tips for Others
If you’re considering a similar project, here are a few tips:
  • Ensure all sensors share the same 3V3 power source to avoid any connectivity issues.
  • The MH-Z19C’s temperature reading is close enough to the DHT22’s, so you can omit the DHT22 if you’re short on space.
  • Don’t forget to leave space in the enclosure for an LED if you want to add notifications in the future.
This project has been a huge success for me, and I’m excited to see how others might adapt or expand on this setup. If anyone has questions or needs help troubleshooting, feel free to reach out!
Happy building! :rocket:
