I’ve recently undertaken a DIY project to create a custom RF remote control for my smart home setup, and I wanted to share my experience with the community. This project has been a fantastic way to integrate more functionality into my home while learning about ESPHome and RF technology.
The Motivation
I’ve always been passionate about home automation, but I wanted a more seamless way to control my outdoor lights, especially during the winter months when it gets dark so early. My old car’s backup lights were barely functional, and relying on my phone to turn on the lights was cumbersome and slow. I needed a solution that was quick, reliable, and didn’t require fumbling with my phone in the cold.
The Setup
The project was surprisingly straightforward. I used an ESP32 board, which I sourced from AliExpress for a very reasonable price, and paired it with an RF remote control module. I opted for a model with a relay since MOSFET-based modules weren’t suitable for this application. The remote control I chose was from Amazon, but I’ve heard similar models are available on AliExpress at a fraction of the cost.
Here’s a quick breakdown of the components I used:
- ESP32 Development Board (AliExpress)
- RF Remote Control Module (Amazon)
- Relay Module (AliExpress)
- USB Power Supply
The Process
- Hardware Assembly: I connected the ESP32 to the RF receiver module, ensuring the power and ground pins were correctly aligned. The relay was connected to a GPIO pin on the ESP32, which would trigger the light switch.
- Firmware Installation: Using ESPHome, I configured the ESP32 to recognize the RF signals from the remote control. This involved setting up the GPIO pin and ensuring the internal pull-up resistor was enabled for stable operation.
- Integration with Home Assistant: Once the firmware was uploaded, I integrated the device into Home Assistant. I set up a binary sensor to detect button presses and linked it to my outdoor lights, creating a simple automation that turns them on and off with a press of the remote.
The Results
The system has been working flawlessly for several months now. The RF signal range is excellent, and the reliability is something I didn’t expect from such an affordable setup. It’s been a lifesaver during the winter months, allowing me to easily illuminate my driveway without fumbling with my phone.
Tips for Others
If you’re considering a similar project, here are a few tips:
- Always check if the remote control module uses a relay or a MOSFET. Relays are more reliable for switching loads.
- Source components from AliExpress for significant cost savings, but ensure they’re compatible with your setup.
- Take your time with the firmware configuration. ESPHome has a steep learning curve, but the community forums are invaluable.
This project has been a fantastic way to enhance my smart home setup while learning new skills. I’d love to hear about any similar projects or improvements others have made!
Cheers,
