As a fan of RGBIC lights, I’ve always been intrigued by creative lighting projects. Recently, I decided to take on a fun DIY project to create my own RGBIC clouds. It’s a fantastic way to add a unique touch to any room, and I’m excited to share my experience with you!### Materials Needed:- RGBIC Govee Lightstrips (I used the H6146 model)- Polyfil- Poster Board- Gorilla Tape- Hot Glue Gun & Sticks### Step-by-Step Guide:1. Planning the Design: I started by visualizing how I wanted the clouds to look. Sketching out the shape helped me determine the size and number of lightstrips needed. For a 12x14 room, I found that three 32.8ft lightstrips worked perfectly.2. Cutting the Poster Board: Using the sketch as a guide, I cut the poster board into cloud shapes. This was a bit tricky, but taking my time ensured clean lines.3. Attaching the Lightstrips: I carefully glued the RGBIC lightstrips to the back of the poster board using hot glue. Making sure the lights were evenly spaced was key for an even glow.4. Adding the Polyfil: To give the clouds a fluffy appearance, I stuffed polyfil between the poster board and the lightstrips. This step really brought the clouds to life!5. Securing Everything: Using Gorilla tape, I secured the edges and any loose parts. This ensured the structure was sturdy and ready to hang.6. Final Touches: I sealed any exposed edges with hot glue to prevent fraying and gave the clouds a final inspection to make sure everything was in place.### Tips for Success:- Measure Twice: Ensure your lightstrips are long enough for your design.- Test the Lights: Before assembling everything, test the lightstrips to confirm they’re working properly.- Seal Carefully: Use hot glue to seal any gaps, preventing dust or debris from getting inside.### The Result:The finished clouds add a magical touch to my room, and they’re a hit whenever I have guests over. It’s amazing how a simple project can transform a space!If you’re looking for a fun and creative way to enhance your home’s lighting, I highly recommend giving this DIY project a try. Let me know if you have any questions or if you’ve tried a similar project—I’d love to hear about it!Happy crafting! ![]()
