Hello fellow DIY enthusiasts! I wanted to share a solution I came up with for my security alarm system using Wyze devices. I’ve been trying to find a reliable way to tie my Wyze door and motion sensors into an alarm system, and after some trial and error, I finally found a setup that works great!
The Problem:
I had Wyze door and motion sensors, but I needed a way to trigger an alarm when they detected something. I tried using individual sensors to turn on an alarm, but it was hard to arm and disarm the system. I also experimented with rules, Alexa, and IFTTT, but nothing quite did what I wanted.
The Solution:
I decided to use a Wyze socket as the alarm itself. Here’s how I set it up:
- Alarm Master Switch: I plugged the alarm socket into another Wyze socket called “Alarm Master.” This acts as the main switch for the entire system.
- Arming the System: When I toggle the “Alarm Master” switch on, it powers on the alarm socket. If there’s a trigger event (like a door opening or motion detected), the alarm sounds.
- Disarming the System: When I toggle the “Alarm Master” switch off, it turns off the alarm socket, effectively disarming the system.
Additional Features:
- I set up rules to enable notifications for all cameras and sensors when the system is armed.
- I added an IFTTT routine to send me a text message and trigger a horn sound on my phone if the alarm is activated while I’m away.
Why It Works:
This setup is simple yet effective. It doesn’t require any additional hardware beyond what I already had, and it’s easy to customize. The best part is that it’s reliable—I’ve been using it for over a week without any issues!
Tips for Others:
- Make sure all your sensors are properly configured in the Wyze app.
- Test your setup thoroughly to ensure everything works as expected.
- If you’re looking for something more sophisticated, this is a great temporary solution until you can invest in a full security system.
I hope this helps someone else who’s trying to create a DIY security system. It’s been a great learning experience, and I’m thrilled with how it turned out!
Cheers,
Dave
