DIY Sensor Data Logging - Success After Challenges
I wanted to share my journey of setting up a sensor data logging system in Home Assistant. It’s been an interesting process with some bumps along the way, but I’m thrilled with how it turned out!
The Goal
I wanted to create a system that records temperature data every minute and saves it to a file. This would allow me to track environmental changes over time and use the data for analysis later.
The Setup
I started by configuring my configuration.yaml file to enable the notify component for file logging:
yaml
notify:
  • name: Test Data
    platform: file
    filename: Test_Data
    timestamp: true
Next, I set up my sensor in sensors.yaml to pull temperature data from my MQTT broker:
yaml
  • platform: mqtt
    state_topic: “ds18bq/temperature”
    force_update: true
    unit_of_measurement: “°F”
For automation, I created a rule to trigger every minute and log the sensor value:
yaml
Automation that writes the Temperature data to a file every minute
  • alias: Check Test Temperature
    initial_state: true
    trigger:
    platform: time
    minutes: ‘/1’
    seconds: 00
    action:
    service: notify.test_data
    data:
    message: ‘{sensor.test_temperature}’
The Challenges
At first, I wasn’t sure if I was configuring everything correctly. My main questions were:
  1. Am I setting this up right? I wasn’t entirely confident about the notify component configuration.
  2. Where is my data file? The logs showed the notify component was active, but I couldn’t locate the output file.
The Solution
After some research and troubleshooting, I realized the file was being saved in the default Home Assistant logs directory. I adjusted the filename path in my notify configuration to specify a custom location for better organization:
yaml
filename: /path/to/your/logs/Test_Data
The Results
Now, every minute, the temperature data is neatly logged in my specified file. It’s been incredibly useful for monitoring trends and even for debugging other parts of my setup.
Tips for Others
  • Check Log Paths: Make sure you know where your files are being saved. Default paths can sometimes be hidden or unexpected.
  • Enable Debug Logging: This was invaluable for verifying that my automation was running as expected.
  • Test Incrementally: Start with basic configurations and gradually add complexity. This makes it easier to isolate issues if something goes wrong.
It’s amazing how much you can learn by diving into these kinds of projects. I’m already brainstorming new ways to expand my logging system—maybe adding more sensors or even visualizing the data with a dashboard!
If anyone has questions or tips about data logging, I’d love to hear them. Happy automating! :rocket:
