Hey everyone! I wanted to share my recent project where I transformed my Venetian blinds into smart blinds using ESPHome. It’s been a fun and educational journey, and I’d love to hear your thoughts or tips on improving it further!
I’ve been using ESPHome for a while now, but this was my first time diving into creating a custom cover component. The goal was to control the blinds using a servo motor and a rotary encoder, allowing me to adjust the slats gradually. Open and close actions were straightforward, but getting the position to update in Home Assistant was a bit tricky.
After some research and trial and error, I managed to set up the rotary encoder to adjust the position smoothly. The logs were a bit confusing at first, but breaking down the problem helped me identify where the data was getting lost in translation. In the end, I found a workaround by adjusting how the position data was handled in the YAML configuration.
Here are a few tips I’d like to share for anyone tackling a similar project:
- Start Simple: Begin by testing each component individually before integrating them. This helps isolate any issues early on.
- Use YAML Wisely: While YAML can be a bit overwhelming, taking the time to structure it properly makes maintenance much easier.
- Log Everything: Use the logger extensively to track data flow and identify where things might be going wrong.
- Community Support: Don’t hesitate to reach out to the community for help. The ESPHome and Home Assistant forums are fantastic resources!
This project has given me a new appreciation for the flexibility of ESPHome and the possibilities it opens up for custom home automation. I’m already brainstorming my next project—maybe something with smart lighting or a custom sensor setup!
If anyone has tips or alternative approaches they’ve used for similar projects, I’d love to hear about them. Happy tinkering! ![]()
