I recently decided to explore a fun and practical project to enhance my smart home setup—building a custom smart curtain control system. While I’ve managed to get my roller blinds working with a Tuya RF remote, I ran into a bit of a snag when trying to automate the process through the Smart Life app. Initially, I thought a simple scene setup would do the trick, but I encountered an issue where the command wouldn’t trigger on a single tap. Instead, it would open a window asking me to enable the function manually. Frustrating, to say the least!After some research and trial and error, I stumbled upon a workaround that involved tweaking the scene settings and using a combination of manual inputs. It was a bit of a puzzle, but solving it gave me a great sense of accomplishment. Now, my curtains are seamlessly integrated into my smart home ecosystem, and I can control them with ease using my voice or the app.For anyone looking to embark on a similar project, here are a few tips I’ve gathered along the way:- Start Small: If you’re new to DIY smart home projects, begin with a single curtain or small setup to get a feel for the process.- Research Compatibility: Not all devices are created equal. Spend time researching which remotes and controllers are compatible with your existing setup to avoid headaches down the line.- Embrace the Learning Curve: Automation can be tricky, but every challenge is an opportunity to learn something new. Don’t be afraid to experiment and tweak your setup until it works perfectly for you.This project was a great learning experience and has added a convenient touch to my smart home setup. If you’re looking for a simple yet effective automation idea, I highly recommend giving this a try!
