DIY Smart Flood Sensor Project and Tips
Hey everyone, I wanted to share a fun DIY project I recently completed to enhance my home’s flood detection system. After experiencing a couple of close calls with water damage, I decided to take matters into my own hands and create a custom flood sensor setup. Here’s how it went down!
The Setup
I purchased a couple of Samsung SmartThings water leak sensors. They’re affordable and come with some extra sensors, which immediately caught my eye. My plan was to use one sensor indoors as-is, but the other needed a bit more creativity since I wanted to monitor my outdoor sewer line.
The Hack
For the outdoor sensor, I decided to repurpose it to monitor the sewer line. Here’s what I did:
  1. Drilling Holes: I drilled two holes in the sensor cap to fit some stiff copper wire.
  2. Mounting: Using double-sided velcro, I mounted the sensor on top of the cap.
  3. Wiring: I cut two pieces of copper wire, stripped the ends, and soldered them to the sensor pads. I made sure to keep the soldering quick to avoid overheating the sensor.
  4. Insulation: To protect the connections, I applied some epoxy.
  5. Covering: Finally, I placed a decorative rock over the setup to keep it hidden and prevent false alarms during rain.
The Results
This setup has been working perfectly for months now! It’s given me peace of mind knowing that any potential sewer issues will be caught early. The only minor inconvenience is that I’ll need to replace the battery in about six months, but that’s a small price to pay for such reliable monitoring.
Tips for Others
If you’re considering a similar project, here are a few tips:
  • Plan Ahead: Measure the depth of your sewer line to determine how long your wires need to be.
  • Soldering: Be quick and careful to avoid damaging the sensor.
  • Protection: Use epoxy or another method to secure your connections and protect them from the elements.
  • Camouflage: Find a way to hide your setup to keep it looking neat and prevent accidental tampering.
Looking Ahead
I’m already brainstorming my next DIY project. Maybe I’ll tackle a similar setup for my basement drain or even integrate some automation to alert me via my smartphone if any leaks are detected. The possibilities are endless!
If anyone has questions or suggestions about this project, feel free to reach out. I’d love to hear how others are enhancing their home security and automation systems!
Cheers,
