Hey everyone, I wanted to share my recent DIY smart home automation project with you all. It was a lot of work, but the result is amazing! ![]()
I decided to automate my living room lights using a combination of Hubitat and smart bulbs. The goal was to create a seamless experience where I could control the lights through voice commands, a mobile app, or even set up schedules. Here’s how I did it:
Planning: I started by mapping out all the lights in my living room and deciding which ones I wanted to automate. I chose Hubitat because of its flexibility and compatibility with multiple devices.
Setup: I installed the Hubitat hub and connected it to my Wi-Fi. Then, I added the smart bulbs one by one, making sure each was properly paired with the hub. The process was straightforward, but I had to troubleshoot a few connection issues.
Automation: Using Hubitat’s app, I created a simple automation rule where the lights turn on at sunset and off at midnight. I also set up voice commands through Alexa so I can control the lights hands-free.
Testing: Everything worked perfectly during testing! I was thrilled to see the lights respond instantly to my commands. It’s such a convenience, especially in the evenings when I’m busy with other tasks.
Tips: For anyone planning a similar project, here are my top tips:
- Start Small: Don’t overwhelm yourself by automating everything at once. Start with one room and expand as you get comfortable.
- Read Reviews: Do your research on hubs and devices to ensure they’re compatible and reliable.
- Backup Plan: Keep traditional switches or remotes handy in case of any technical glitches.
This project has completely transformed my living space, and I couldn’t be happier with the results. If you’re thinking about dipping your toes into smart home automation, I highly recommend giving it a try! ![]()
Any questions or suggestions? I’d love to hear from you!
Cheers,
