DIY Ultrasonic Sensor & Smart Thermostat Integration Tips
I recently embarked on a DIY project to create an ultrasonic distance sensor with a Zigbee interface to monitor my vehicle in the garage. The process was quite rewarding, though not without its challenges! The most difficult part was mounting the Adafruit micro USB breakout, but I managed to make it work by using a slightly larger enclosure for easier assembly. If anyone is interested in replicating this, I’d be happy to share more details and tips!
On another note, I’ve been experimenting with integrating my Sensibo thermostat with separate Zigbee temperature sensors. The goal was to have the thermostat base its temperature readings on sensors located in different parts of the room rather than its built-in sensor. While this wasn’t straightforward at first, I managed to configure it successfully by adjusting the climate entity settings. This has significantly improved temperature control and comfort in my space!
If anyone has tips for optimizing similar setups or has faced challenges with integrating smart devices, I’d love to hear your experiences. Let’s keep the knowledge sharing going! :rocket:
