DIY USB Port Addition to Wyze Floodlight Pro: A Cost-Effective Solution
Hey everyone, I wanted to share my experience with adding a DIY USB port to my Wyze Floodlight Pro. While I understand Wyze’s reasoning for removing the second USB port, I still wanted the convenience of having an extra port for my setup. After some research and brainstorming, I came up with a simple yet effective solution that didn’t break the bank!
The Problem
I noticed that the Wyze Floodlight Pro lacked an additional USB port, which limited my ability to connect extra devices like a backup camera or power bank. While Wyze’s reasons for removing the port made sense for most users, I felt it was a necessary addition for my specific use case.
The Solution
I decided to purchase a weatherproof surge protector with built-in USB ports and AC outlets. This not only provided me with the extra USB ports I needed but also added the convenience of additional AC outlets without the need for professional installation. I chose the Weatherproof Surge Protector with USB Ports for its compact design, IPx6 waterproof rating, and affordability.
Installation Process
  1. Preparation: I cut off the plug end of the surge protector and stripped the insulation to expose the black, white, and green wires.
  2. Wiring: I carefully stripped the wires and connected them to the floodlight’s junction box. I made sure to twist the green ground wires together and secure them under the junction box’s ground screw for safety.
  3. Mounting: I temporarily placed the surge protector near the floodlight while I finalized the wiring. Once everything was secure, I mounted it permanently on the brick wall using heavy-duty adhesive mounts.
Benefits
  • Cost-Effective: This solution saved me hundreds of dollars in electrical work and extra hardware.
  • Convenience: Having an extra USB port and AC outlets on the same side of the house as my floodlight has made my setup much more versatile.
  • Durability: The IPx6 rating ensures it can withstand heavy rain and even occasional water jets, which is perfect for my outdoor setup.
I’m thrilled with how this DIY project turned out. It not only solved my immediate problem but also added redundancy to my security setup. I can now use an OG-Telephoto cam for zoomed-in surveillance and have a backup camera in case of AWS outages. Plus, the surge protector’s built-in outlets mean I no longer need to run extension cords or hire an electrician for new outdoor outlets.
If you’re considering a similar upgrade, I highly recommend this approach. It’s a great way to customize your Wyze Floodlight Pro without breaking the bank or compromising on safety and functionality. Happy tinkering! :bulb::sparkles:
