Hi all, I wanted to share a DIY project I recently completed to address my frustration with unreliable outdoor Z-Wave motion sensors. After several failed attempts with commercially available sensors, I decided to take matters into my own hands and convert an inexpensive outdoor motion sensor light into a Z-Wave motion sensor. I’d love to hear your thoughts or suggestions on this setup!
The Problem:
I’ve had consistent issues with Z-Wave outdoor motion sensors failing within a year, despite being exposed to the same conditions as my inexpensive, decade-old motion sensor lights. This discrepancy led me to wonder if I could repurpose one of these reliable lights into a Z-Wave sensor.
The Solution:
I chose the Vision ZL7431 Z-Wave relay for its compact size and decided to integrate it with one of my existing outdoor motion sensor lights. Here’s how I wired it up:
- White Wires: Connected power mains, motion sensor, ZL7431 relay, and lights.
- Black Wires: Connected power main, ZL7431 relay, and motion sensor.
- Green Wire: Connected ZL7431 relay, red wire from motion sensor, and black wires from lights.
- Capped Wires: Yellow, red, and blue wires from the ZL7431 relay.
The Result:
This setup now triggers my Vera controller to activate additional exterior lights when motion is detected in my driveway. The motion sensor light’s built-in timer controls its on-time, while Vera handles the others. It’s been working flawlessly for about a month now!
Safety Disclaimer:
If you’re not confident working with 120V wiring, I strongly advise against attempting this project. Always ensure the circuit is powered off during installation and triple-check your connections before restoring power.
Seeking Feedback:
I’d love to hear if anyone else has tried something similar or has suggestions for improvement. Would you consider this approach for your setup? Any potential issues I might have overlooked? I’m also curious if others have success with different relay models.
Thanks for reading, and I look forward to your insights!
