DIY Zigbee Water Meter Setup Success Story
I’ve always been fascinated by the idea of creating a custom solution for monitoring water usage. After struggling with inconsistent Wi-Fi signals around my water meter, I decided to explore Zigbee as a more reliable alternative. Here’s how I successfully built a Zigbee water meter using an inductive sensor and a CC2530 module!
The Challenge
Finding a water meter setup that works seamlessly with Zigbee was no easy task. Most existing solutions rely on ESPHome or Wi-Fi, which weren’t ideal for my setup due to poor Wi-Fi coverage. I wanted something low-power, reliable, and fully integrated into my Home Assistant ecosystem.
The Solution
I stumbled upon a fantastic guide using an inductive sensor and the PTVO firmware. The process involved several key steps:
  1. Sensor Connection: The inductive sensor detects water flow and sends signals to the CC2530 module. A 4N35 optocoupler was essential to handle voltage differences between the sensor (5V) and the module (3.3V).
  2. Power Management: A 5V power supply was adjusted to 3.3V using a buck converter to ensure stable operation.
  3. Firmware Flashing: The CC2530 module was flashed with the PTVO configurable firmware using the TI FLASH-PROGRAMMER tool. Configuring the firmware settings was straightforward and crucial for proper communication with Home Assistant.
  4. Home Assistant Integration: Pairing the device with Home Assistant was seamless. I set up a counter entity to track water usage and created automations to increment the counter based on sensor triggers. To visualize consumption trends, I utilized the utility_meter integration for hourly, daily, and weekly data tracking.
The Outcome
This DIY project exceeded my expectations! The water meter now reliably tracks usage without any Wi-Fi dependency. The integration with Home Assistant allows me to monitor consumption patterns effortlessly. The best part? The setup is entirely self-contained and runs on Zigbee, ensuring rock-solid performance.
Tips for Others
  • Research Components Thoroughly: Ensure all components are compatible with your voltage requirements.
  • Follow Firmware Configuration Carefully: Spend extra time setting up the firmware to match your specific needs.
  • Leverage Home Assistant’s Flexibility: Take advantage of automations and integrations to streamline your setup.
If you’re looking to enhance your water monitoring setup or explore Zigbee integration, I highly recommend giving this DIY approach a try! Happy tinkering! :potable_water::bulb:
