Hi everyone, I recently encountered a frustrating issue with Docker and Z-Wave in my Home Assistant setup. The error message I was getting was terminate called after throwing an instance of 'std::bad_alloc', which I later found out was related to memory allocation problems. After trying various troubleshooting steps, I decided to start fresh by creating a new Docker container pointing to a blank configuration folder. Surprisingly, this worked, which led me to believe that the original config folder might have had permission issues or some corrupted files.
I then moved all my YAML files and configurations to the new folder, and after renaming everything appropriately, the system started working smoothly again. It was a bit of a rollercoaster, but it taught me the importance of regular backups and checking file permissions. If anyone else is facing similar issues, I highly recommend trying this approach—it might save you a lot of time and frustration!
On a lighter note, I also stumbled upon a really helpful guide on using JavaScript for logging in Home Assistant. It involved importing the LoggerFactory and using it to log messages, which I found quite elegant. If you’re into scripting and want to keep track of your automation scripts, this could be a great way to add some transparency to your setup.
Lastly, I wanted to share a quick tip for anyone dealing with ESP32 and HC-SR04 sensors on batteries. I noticed that the battery life wasn’t as impressive as I hoped, so I started experimenting with power-saving modes and adjusting the sensor’s polling intervals. This significantly improved the longevity of the batteries, which was a much-needed fix for my garage sensor project.
I hope these experiences and tips can help someone out there. Happy automating! ![]()
