Does anyone know why my door and window sensor shows the wrong time? I have more Aqara devices, and all my sensors ( I have like 20) and all are the same from day one (Installed 2 weeks ago)
And it’s just the door sensor? That’s really odd
Yes, just the door sensor, the other devices are showing the time just fine
crazy - and there are 3 versions
Which one exactly?
This one Aqara Door and Window Sensor - Aqara
So not the T1 ? Did you contact the support already?
Mine is working fine
Just to narrow it down: where exactly do you see the wrong time, in the device log in Aqara Home, or in the timestamp of the last open/close event? And is it off by a fixed amount, for example exactly a few hours, or completely random?
If it’s a fixed offset, it could be a time zone issue for that one device. If it’s random, I’d contact support with a screenshot. I have the P2 on my garage door and the timestamps there have always matched my phone.
In the device, when you see the logs and status.
Thanks. And is the time off by a fixed amount, for example always exactly a few hours, or does it vary? If it’s a fixed offset, I’d check the time zone of the hub the sensor is paired to. If it varies, support is the better route, as DEChrisE suggested.
Frank
My first thought was the time zone (I don’t know where to change it), but if I change it, will the other devices mess it up?
It is exactly an hour behind
Problem solved: The issue was the Aqara App or the Sync process. I changed the app configuration, and now it is showing the time correctly. Thank you all ![]()
