Door sensors range outside
Hi
I need to monitor the status of an outside gate in order to keep our dogs safe in the garden
Does anyone know what range the sensors operate over please
I have an outdoor WiFi AP
many thanks
The outdoor WiFi AP won’t help with the sensor range as the Aqara sensors use Zigbee rather than WiFi.
It will depend on how far the gate is from your nearest Aqara hub/device and what walls it has to go through. I’d probably just try a sensor at the gate first and see how reliable it is.
As it’s for keeping the dogs safe I’d definitely test it for a few days before relying on it.
i have some working over 4 floors, hub in the loft and sensors in the basement.
Hi, exactly what @hector said before! What Aqara hub do you use?
I installed a T2 relay with a neutral wire in my garden light pole, which allowed me to extend the range of the gate sensor. In open field, I can reach about 50 meters.
Looking for the same type of setup to create an automation so when the sliding door opens if a gate is open a push notification is sent to all home users that the dog is not safe to go outside.
That’s extremely helpful-thanks
Not sure is going to be 50 metres outside but also you might get false triggers aswell by other animals
