Does anyone else find the battery life erratic. It can sometimes last weeks, sometimes months (same battery brand). Also one day in may show no charge, the next full charge. Also it only seems to show full or empty, nothing intermediate
@zoinks Hi there! Thanks for sharing your experience with the Doorbell G4. Battery behavior can definitely be a bit of a mystery sometimes, but there are a few technical reasons why you might be seeing these fluctuations.
First, regarding the “full or empty” display with no intermediate levels: this is often related to the type of battery you are using. If you are using rechargeable lithium-ion batteries, they maintain a stable voltage until they are nearly depleted, which can cause the app to show high battery levels (like above 90%) for a long time before dropping suddenly. Additionally, if you use NiMH batteries (1.2V), the battery statistics can become inaccurate. For the most consistent readings and performance, LR6 alkaline AA batteries are recommended.
As for the erratic life (lasting weeks vs. months), several factors can influence this:
- Power Saving Mode: In this mode, the PIR detection is turned off, and the doorbell only activates when the button is pressed or via the app. This greatly extends battery life compared to Normal Mode. If you have this mode enabled, usage frequency is the main driver of battery drain.
- Loitering Detection: If the detection interval is set too short, the doorbell may trigger frequently, shortening battery life. Also, a farther detection distance can lead to more triggers from nearby activity.
- HomeKit Integration: If connected to HomeKit, the doorbell may record video continuously when motion is detected until it ends, which consumes more power than using just the Aqara Home app.
- Signal Strength: If the doorbell is far from the repeater (more than 5 meters) or there is wireless interference, it increases transmission power, leading to higher consumption.
It’s great that you’re paying attention to these details! If the issue persists despite checking these settings, you might want to try replacing all six batteries with new, same-model LR6 alkaline batteries, as mixing old and new ones can affect performance.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Readings like that are often caused by the cold or by the battery type. Rechargeable NiMH batteries are 1.2 V instead of 1.5 V, so the doorbell sees them as low almost right away, and after it jumps between full and empty. The cold does the same: the voltage drops in the morning and comes back in the afternoon.
If yours is outside, try lithium AA (not rechargeable). They keep their voltage much better in the cold and the reading should be more stable. And if you have a doorbell wire at the door, power it with that and you won’t think about batteries anymore.
