I purchased the Aqara Doorbell but haven’t mounted yet. I am concerned with the tiny little screws thats supposed used on my brick wall. Do you know of any other screw options that can be used for mounting on brick walls?
Welcome to the forum @mlwalker220. If you’re wanting to screw this into brick or mortar, you’ll need masonry screws (and of course a masonry drill bit) - available at any hardware store. I’d send you a link, but you’ll probably have to bring the mount and test to make sure the screw will fit and sit flush.
You’ll get much debate on on whether it is best to screw into the brick or the mortar. My opinion is for this use-case, a small lightweight device, go with mortar.
Hope you can find the answer.
