During the day the doorbell (G410) works (almost) as expected . However EVERY MORNING the camera is disconnected with a message network error !!! I ‘try again” as suggested 4/5 times then magically the connection is restored. Everything else on my network is working ok (using ha with about 10 devices). Please comment I’m 76 year old newbie who thought I was buying an item that would work out of the box. Now I have no faith that the camera will warn me about anybody outside the house at night.
Later. Will now not connect to network. Returning to Aqara for landfill material
@allen_jackson Thank you for sharing your experience, and I’m sorry to hear about the trouble you’ve been facing with your G410 doorbell. From your description, it sounds like the camera is experiencing intermittent network issues, especially in the mornings, before eventually reconnecting after several attempts.
For the Aqara Doorbell Camera Hub G410, connection problems like image freezing, frame skipping, or choppy intercom are often related to the installation distance between the doorbell and its repeater/chime, or potential Wi-Fi interference. It’s recommended to check if the distance between the doorbell and repeater/chime exceeds the allowable range, and to look for other sources of Wi-Fi interference operating on the same frequency. You might improve stability by moving the repeater/chime closer to the doorbell or changing your router’s Wi-Fi channel.
If the issue persists and your network is otherwise stable for other devices, it may also be worth checking if any settings on your router (like scheduled reboots or power-saving features) could be affecting the doorbell overnight.
I understand how frustrating this can be, especially if you were hoping for a simple, out-of-the-box solution. If you have any thoughts or suggestions for improvement, please consider submitting feedback through manual customer service channels, as this is the best way to have your voice heard.
If you need further troubleshooting or human support, please contact the Customer Service Team via the Aqara Home App (Profile > Help & Feedback > Customer Service) or by scanning the QR code below, which should be efficient:
If you don’t have an Aqara Home account, please click here to create a ticket.
Thank you for sharing your experience with the community. If you discover any solutions or have further thoughts, please share them—your input is valuable for other users too.
@allen_jackson I’m sorry to hear you’re having trouble with your G410 doorbell—no one should have to deal with daily disconnections, especially when you’re relying on it for peace of mind. Let’s try a few steps that might help:
First, check the distance between the doorbell and the repeater/chime. If it’s more than 5 meters, try moving them closer (even small adjustments can help with signal strength) .
Next, confirm your Wi-Fi is on the 2.4 GHz band (the G410 doesn’t support 5 GHz) and that your network name/password has no special characters—these can cause connection issues .
If that doesn’t work, try restarting the doorbell and chime: power off the chime, remove the doorbell battery (or disconnect power if wired), wait 30 seconds, then reconnect. Sometimes a fresh start fixes temporary glitches .
If the problem persists, a factory reset might help. Follow the user manual to reset both the doorbell and chime, then reconnect them to the app .
If none of these steps work, reaching out to Aqara customer service would be the best next step—they can help dig deeper into the issue.
I hope this gets your doorbell back to reliable operation soon. Let us know if you try these steps—we’re here to help!
@allen_jackson I’m sorry to hear you’re having trouble with your G410 doorbell—let’s try to figure this out step by step.
First, the daily morning disconnection and network errors might be related to the connection between the doorbell and the repeater/chime, or Wi-Fi interference. For the G410, check if the installation distance between the doorbell and the repeater/chime exceeds the allowable range, or if there are other Wi-Fi devices operating on the same frequency. Adjusting the repeater/chime location or changing your router’s Wi-Fi channel could help improve stability .
Since it now won’t connect at all, try these steps:
- Power cycle: Cut off the doorbell’s power (if wired) or remove/reinsert batteries, then restore power. Press the doorbell to see if the chime rings—if it does, it may reconnect .
- Reset: Long press the reset button until you hear a confirmation, then try reconnecting via the Aqara Home app .
- Check Wi-Fi: Ensure it’s connected to a 2.4 GHz network (no 5 GHz support) and avoid special characters in the Wi-Fi name/password .
If these steps don’t resolve the issue, please contact Aqara customer service for further help. They can guide you through more specific troubleshooting.
Hope this gets your doorbell back on track—you deserve a reliable smart home setup! ![]()
@allen_jackson I’m sorry to hear you’re having such a frustrating experience with your G410 doorbell—no one should have to deal with daily disconnections, especially when you’re relying on it for peace of mind. Let’s break down some steps that might help, based on common troubleshooting for this issue:
First, since the problem happens consistently in the morning (and now persistently), let’s check the basics. Wi-Fi interference or signal strength could be a culprit—even if other devices work, doorbells are often placed near exterior walls, which can weaken signals. Try ensuring the doorbell is within 5 meters of the repeater/chime with minimal obstacles, as distance or interference (like other 2.4GHz devices) can cause drops .
Next, restarting devices often helps. For wired G410, try cutting power to the doorbell (if possible) for 30 seconds, then restoring it. Also, reboot your router—sometimes temporary network glitches cause this .
Check if your Wi-Fi is 2.4GHz (the G410 doesn’t support 5GHz) and avoid special characters in the network name/password, as these can cause connection issues .
If it still won’t connect, a factory reset (following the user manual) might help refresh the connection, though it’s a bit more involved—take it slow, and you can reach out to customer service if you need guidance .
I totally get why you’re frustrated—tech should work out of the box, especially for someone who just wants reliability. If these steps don’t fix it, reaching out to Aqara’s customer service (via the app or the link provided) could help get a more personalized solution. Fingers crossed one of these tips gets it back to working smoothly!
If you try any of these, feel free to share how it goes—this community might have more ideas too.
Please contact Customer Service Team by Aqara Home App (Profile>Help&Feedback>Customer Service) or scanning the QR code:
