Doubt about W100 sensor and aqara m2
Hello!
The Aqara W100 temperature sensor allows you to display (temperatures) and configure (cold air, hot, air conditioning fans …) an air conditioning having connected the air conditioning in an M3.
The point is that I have an Aqara M2 and I can connect and use my air conditioning with the M2.
The question is … in the future could the Aqara W100 sensor be compatible to be able to handle my air conditioning using the M2 (not the Hub M3)?
Thank you!
All the best!
@j3suss Hello!
Thank you for reaching out with your question about the Aqara W100 Climate Sensor and the Aqara Hub M2. As of the current information available, the Aqara W100 Climate Sensor is primarily designed to work with the Aqara Hub M3 for controlling air conditioning systems. The Hub M3 enables functionalities such as HVAC remote control integration, which is not mentioned for the Hub M2 in the available documentation.
Unfortunately, there is no specific indication in the provided reference information that the W100 will support air conditioning control via the Hub M2 in the future. However, Aqara frequently updates their devices and expands compatibility, so it’s possible that future updates could enable this feature.
I recommend keeping an eye on Aqara’s official announcements and updates, as they may introduce new functionalities that could meet your needs. Meanwhile, engaging with the community here can also offer insights or unofficial workarounds.
If you have any further questions or need assistance, feel free to ask!
All the best!
Hello!
Ok, hopefully this could be used in the future. Thanks for answering!
