Hi, I’m using a U200, which is bound to my matter network (Apple HomePod Mini). I am not using any Aqara hubs. Firmware of the U200 is 3.0.0_0085
My U200 is programmed to use the silence mode till 07:00 in the morning. Today I did notice, that the lock was still in silent mode at 07:50. I did check the Aqara app, the timezone for my account was correct (CEST+2).
Are there any known issues with DST changes? I will check again tomorrow morning, but my fair guess would be, that the lock does not respect the timezone settings correctly.
Hi, I never did change the timezone after the initial setup.
I don’t have the turn feature enabled.
However the issue seems to have been solved, after I did change the silent mode - I guess the time have been synced.
Same problem here, after the DST change in Europe (25 Oct 2026).
Setup:
Aqara Smart Lock U200 Lite, firmware 3.1.0.5
Matter over Thread, controlled by Home Assistant (also shared with Google Home). No Aqara hub.
What happens:
Silent mode is scheduled in the Aqara Home app from 21:00 to 09:00.
Since the clocks went back, the lock enters silent mode one hour early. At 20:08 and 20:24 (local time) it locked and unlocked slowly/silently.
If I change the start of silent mode to 22:00, at 20:35 it unlocks fast again. So the silent-mode schedule is running 1 hour ahead (still on summer time, UTC+2).
What I checked:
The Matter Time Synchronization cluster on the lock is correct: UTC time is right, TimeZone = Europe/Madrid (+3600), DSTOffset already has the 2027 entries, and LocalTime reads the correct local time.
The timezone in the Aqara Home app is correct.
No firmware update is offered.
So the lock knows the correct time over Matter, but the silent-mode schedule seems to use an internal clock/offset set via Bluetooth from the Aqara app that does not apply DST.
Questions:
Is there a way to force the lock to resync its time / timezone from the Aqara app without re-pairing?
Is a firmware fix planned so the silent-mode schedule follows DST (or uses the Matter local time)?
For now I shifted the schedule to 00:00–09:00 as a workaround, but I will have to change it again in March.
